Topic "Trouble When Active Mode Is Required By Host"
moonshell
Hi
I am having trouble with just one account when using WinSCP. I have searched the forums but haven't found a solution.
I use WinSCP successfully with a number of different hosts. All those accounts are set up with pretty standard settings including that they are all done in passive mode and not with a numeric IP address.
The problem child is a small local host. They require a numeric IP address and passive mode unchecked. They have no trouble getting in with my log-in from various locations and using WinSCP. But I can't get in successfully.
At first it was just timing out so I made the time out 30 seconds instead of 15. Now I get in but here is the error I get:
Quote:
Error directory '/directory_name'
The server cannot open connection in active mode. If you are behind a NAT router, you may need to specify an external IP address. Alternatively, consider switching to passive mode.
Can't open data connection.
When I click OK I am connected to their server but I cannot access any files or directories. There is just a blank window.
I have tried excluding the IP address from the Windows firewall with no change.
I used to get a similar message but when I clicked OK everything just opened up fine.
The host owner says they have done all they can and that the problem is my end so I will have to solve it. They are problematic in other ways. I have moved most projects to other hosts but the client is dedicated to them for a few remaining projects that still need some attention from time to time.
Is there anyone who can suggest a solution?
Thanks!
So did you try to specify your external IP address in WinSCP preferences?
http://winscp.net/eng/docs/ui_pref_network
Is you local network reachable from their network (or Internet in general) at all?
fooliping
Hi, is there a way to specify/use external IP address in WinSCP using script?
See http://winscp.net/eng/docs/rawconfig
