Topic "File comparison"
vavroch
i have a problem with file comparison. I have one local and one remote file. This file shuld be same. My task is test if all bytes is same (could be text or binary file) for example by CRC or MD5 hash. Im using command:
winscp /console /passive /command "open -explicitssl -certificate="... ftps://re ... "put ..." "exit"
synchronize compare only date and filesize, how to use for example COMP or FC command?
Most important - Im looking for batch file solution
WinSCP cannot use an external application for comparing files.
vavroch
A je mon vrtit nějakm způsobem přes WinSCP CRC souboru?
Zalezi na serveru. Obecne spis ne.
Viz: http://winscp.net/eng/docs/ui_properties#checksum
