Topic ".NET session.listDirectory + Mask/Filter"
jfRoland
Is it possible to apply a mask when reading files in a directory when using WinSCP within VS2010
I have to search for files in directories that contains thousands of file. It is really slow if I can't put a filter on my search. (It is possible with WinSCP exe)
For example :
Dim directory As RemoteDirectoryInfo = session.ListDirectory("/export/org/backup/*ZZZ*o") to get all files in directory backup with filename containing ZZZ and ending with o
WinSCP does not support this. What protocol are you using? Note that most protocols, including FTP and SFTP, does not allow filtering anyway.
jfRoland
I use Protocol.Sftp
I thought it exists because it seems to be implemented in WinScp application. In WinScp when you apply a filter before to select directory, it is so fast to get filtered files list that I thought it was filtering at the server level.
Thanks for your reply.
Are you referring to Filter function in WinSCP GUI? This is done on client side.
