Topic "Winscp.com is not working"
neelakandan
winscp.com commandline utility is not working in production server
it is working good in test server
code inside the bat file
C:
CD\Program Files (x86)\WinSCP
winscp.com /command "option batch abort" "option confirm off" "close" "exit"
when i execute the bat file in test server output like this
NULL
C:\Windows\system32>C:
NULL
C:\Windows\system32>Cd\Program Files (x86)\WinSCP
NULL
C:\Program Files (x86)\WinSCP>winscp.com /command "option batch abort" "option confirm off" "close" "exit"
batch abort
confirm off
No session.
NULL
when i execute the bat file in production server output like this
NULL
NULL
NULL
NULL
Did it ever work on the production server? What is exit code of winscp.com?
it is working in production server
from yesterday only it is not working
it is urgent.please give me some suggestion
If exit code is 3, you are possibly a victim of this issue:
http://winscp.net/tracker/show_bug.cgi?id=996
Currently, the only known workaround is to restart the server.
CODE IN PRODUCTION SERVER
BAT FILE CODE :
"C:\Program Files (x86)\WinSCP\WinSCP.com" -script=C:\temp\SFTPOUTPUT.TXT
SCRIPT FILE CODE :
option batch abort
open sftp://112:thEWape2@ftp.alphamcs.com:22
close
IS ANY OTHER WAY TO SOLVE THIS ISSUE
IT IS NOT POSSIBLE TO RESTART THE SERVER
SAME PROCESS IS SCHEDULED IN TEST SERVER IT IS WORKING GOOD FOR PAST TWO MONTHS
WITH IN TWO DAYS WE HAVE THE ISSUE IN PRODUCTION SERVER
It depends on frequency or starts. There's no other workaround as of now.
neelakandan
we restarted server yesterday it was works good
again we have same the same issue today
neelakandan
when i execute the bat file manually it works good
through xp..cmdshell it is not working
There's some resource that is exhausted in scheduler's (or similar) session.
