Topic "3000 and more files to download in one execute process"
Hi guys!
I have situation in which I have more than 3000 files of small size to download. Currently my time out time is around 1 hour. When I am connected to my remote ftp server, I can download all the files using GUI. But when I am using script task inside SSIS package, I am able to download say 700 files and then my package would be fail.
Error Message: The process exit code was "1" while the expected was "0".
Any help would be appreciated!!!
To generate log file, use /log=path_to_log_file command-line argument. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
