Topic "Invalid access to Memory"
mkruer
Using Version 5.2.3 (Build 3436) on windows 7 64-bit SP1
For the error to show up, you need to have WinSCP try to automatically launch putty on connection using SCP
View > Preferences > Integration > Application > Putty > "Automatically open new Sessions in PuTTY" is enabled it generated the follow error
This error only occurs when you are launching WinSCP the first time, if you already have WinSCP running and then open a new session then Putty will open correctly.
This bug is being tracked already:
http://winscp.net/tracker/show_bug.cgi?id=1037
