Topic "E-mail notification, help needed"
costasppc
I am using WinSCP command line (great tool) with the following script:
option batch continue
open <USER>@DOMAIN -passive=on
put C:\FiletoUpload\file
I need to add an e-mail notification to get success or error. I have found in the WinSCP site the following script, but how to insert it in my script?
winscp.com /script=example.txt
if errorlevel 1 goto error
echo Success
sendmail.exe -t < success_mail.txt
goto end
:error
echo Error!
sendmail.exe -t < error_mail.txt
:end
Best regards
Kostas
That code is a Windows batch file that runs WinSCP (and its script). Not other way around.
costasppc
Thank you for your reply,
Is there a way to combine both my code and the notification code?
Best regards
Kostas
In the above example the script.txt is your WinSCP script.
costasppc
Thank you,
You mean the winscp.com /script=example.txt
Yes. Sorry for mistake.
