Topic "Trouble with special character in password"
k3flo
i'm trying to connect to an SFTP Server using the latest beta release (5.2.4 beta).
Connecting via WinSCP.exe works fine.
Connecting via .NET (4.0) assembly fails on password authentication.
I reflected the WindSCPnet.dll and found the issue. The SessionOptionsToOpenArguments()-Method in Session.cs UriEscapes the Password using "Uri.EscapeDataString()". The Problem is that the Uri.EscapeDataString()-method returns "%C2%A7" for the character "" instead of "%A7" which is expected.
Any ideas to force the Uri.EscapeDataString()-method to return "%A7" instead of "%C2%A7"?
Any other ideas?
Thank you.
Correct approach is to make WinSCP accept URL with UTF-8 encoded characters.
http://winscp.net/tracker/show_bug.cgi?id=1062
I'm sending you a dev version with the change for testing.
I appreciate any feedback.
k3flo
Thank you very much.
That fixed the problem. Everything works fine now.
