Topic "COM methods not visible [solved]"
piedmont
Hi Martin,
I'm trying to use the COM version of the .NET wrapper. The dev environment is Microsoft Dynamics NAV (a version which supports only COM DLLs)
I've followed the installation instructions in http://winscp.net/eng/docs/library_install
I'm now able to see the DLL as an available variable type. However when i create variables of type 'WinSCP console interface .NET wrapper'.Session or SessionOptions, no methods or properties are visible/available. (The only type which has visible methods is ISessionEvents)
When we develop custom DLLs for Dynamics NAV (in Vis Studio), we have to specify both the DLL and methods to be COM visible - otherwise we get similar behaviour to the above.
Is there anything we can try to resolve this?
Many thanks in advance,
Piedmont
OS: Windows 2003
WinSCP version: 5.1.7.3446
WinSCP .NET assembly has late binding interface, if that's what you ask about. If you need early binding interface, you can download the assembly source code and change WinSCP.Constants.ClassInterface to ClassInterfaceType.AutoDual.
piedmont
Thanks for your reply Martin.
RE: source code for the .NET assembly - is this the main source download, i.e. http://winscp.net/download/winscp517source.zip ?
I could't find a link to source code specific to the .NET assembly...
Kind regards
Piedmont
piedmont
OK found now - in source code from latest Beta version - https://sourceforge.net/projects/winscp/files/WinSCP/5.2.4%20beta/winscp524source.zip/download
Thank you
Did my suggestion work for you?
piedmont
Yes - thank you Martin - the methods and properties are now visible :D
Is there a way I can mark the topic as solved?
Thanks for your feedback.
No, there's not.
