Topic "SFTP via SSH tunnel with only WinSCP command line?"
andnet81
is it possible to access an SFTP server via an SSH tunnel by using the WinSCP command line tools?
I do not want to use Putty or any other tools to set up the tunnel ahead of time.
WinSCP allows selecting a tunnel in the GUI, but I can not configure it for command line usage.
Tried for hours with ini files and scripts...
Can anyone help?
rac3r5
try this:
C:\>cd "C:\Program Files (x86)"
C:\Program Files (x86)>cd winscp
C:\Program Files (x86)\WinSCP>winscp
winscp> help
rac3r5
This should help you
cd WinSCP
winscp /console /script="C:\temp\myScript.txt"
and myScript.txt should contain.
open sftp://userName:password@host:port
put licence.txt
close
http://winscp.net/eng/docs/commandline
andnet81
Guys, seriously. Did you read my posting?
The importand word is "tunnel".
tomb
Did you try the Tunnelxxxx parameters in the -rawsettings option?
http://winscp.net/eng/docs/rawsettings
werewhelk
I found this post while trying to do the same thing (non-interactive start of a session through a tunnel).
It almost works, but I'm still getting prompted for the password for the tunnel host.
I tried using TunnelPassword= but this doesn't seem to do anything.
I've tried it both with a cleartext password and also using the encrypted string lifted straight from the INI file.
Does anyone have a solution, or am I just being dumb ?
Edit: I've found the solution. You need to use the "TunnelPasswordPlain=" setting.
I have added this to documentation:
