Topic "What can cause the famous "error encountered while setting.""
SouperGrover
Hi there,
I've read through the forums regarding the famous "error while setting permission and or timestamp" message and I know that setting the options to ignore these messages is the answer. But what on an FTP server causes this to occur? I need to be able to setup a test FTP server that makes WinSCP generate this message, but I don't know how to configure the permissions/settings to do so. Any advice on how to do this?
See here:
http://winscp.net/eng/docs/message_preserve_time_perm
On Unix servers you can reproduce this by having a file that you have a write permissions to, but that is not owned by you.
SouperGrover
Thanks, Martin. I read that link you sent me quite a few times before posting, but the answer filnally cliked once I saw you phrase it a different way. But it's clearly in the documentation already.
Thanks again
SouperGrover
OK, so while I understand what you mean by your answer, I'm not sure how to implement it on a Linux server. I've tried looking it up, but my Google-fu may not be good enough to ask the correct question in this case.
How can I set permissions on a directory that would cause the above behavior?
Thanks!
I'm not sure what piece you are missing. The key point is that the file has to be owned by another user!
