Topic "Update script file for changing file name"
murrayb3024
Our vendor made a change and now we have to modify a script that we have been using for quite some time. Not really sure how to modify it.
What it currently looks like:
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect using a password
# Connect
open sftp://xxxxxxxxxxxxxxx -hostkey="xxxxxxxxxxxxxxxxxxx"
# Upload the file to current working directory
option transfer ASCII
put "\\myfilepath\File.txt" -nopermissions -nopreservetime
# Disconnect
close
# Exit WinSCP
What we have to do now is change the filename to FileMMDDYYYY.txt using the current days values. Is there an easy way to do this?
See similar example:
http://winscp.net/eng/docs/script_download_timestamped_filename
murrayb3024
What script language was my example written in (Like I said I didn't build this)?
I know it isn't vbscript or javascript. Hoping I don't have to rewrite this as we just need to append the date but not sure of the syntax to use.
murrayb3024
Disregard, used a different way of doing. Thanks for taking a look though.
