Topic "C drive Hidden files"
tx4
I am using a c# .net service and calling out to winscp in a process and i am having hidden files written to the C drive for some reason and don't know how to get rid of them. I only noticed these when i showed hidden files. Is there an option command or something that i can use to prevent creating of files?
Version 4.3.9 build 1817 i only have been using this one version.
I am using SFTP protocol
In the GUI preferences under storage i have it pointed to an F drive location.
Here is my script from my code.
// Run hidden WinSCP process
using (Process winscp = new Process())
winscp.StartInfo.FileName = "winscp.com";
winscp.StartInfo.UseShellExecute = false;
winscp.StartInfo.RedirectStandardInput = true;
winscp.StartInfo.RedirectStandardOutput = true;
winscp.StartInfo.CreateNoWindow = true;
if (winscp.Start())
const string quote = "\"";
// Feed in the scripting commands
winscp.StandardInput.WriteLine("option batch abort");
winscp.StandardInput.WriteLine("option confirm off");
winscp.StandardInput.WriteLine("open moveFiles@moveFiles");
winscp.StandardInput.WriteLine("put -delete " + quote + file + quote + " " + quote + destfile + quote);
winscp.StandardInput.Close();
// Collect all output (not used in this example)
string output = winscp.StandardOutput.ReadToEnd();
WriteToErrorLog(output + ArchiveDirectory + DirectoryDateTimeStamp, ErrorLog, LogDirectory);
// Wait until WinSCP finishes
if (!winscp.Has_Exited)
winscp.WaitForExit();
else
WriteToErrorLog("Move to Linux Destination Error " + SourceDirectory, ErrorLog, LogDirectory);
// Success (0) or error?
if (winscp.ExitCode != 0)
sendEmailError("Move to Linux Destination Error ", LogDirectory);
I do not think WinSCP creates any hidden files. Can you show us an example?
Also to use WinSCP from C#, I recommend you to use WinSCP .NET assembly.
http://winscp.net/eng/docs/library
You should upgrade anyway.
Thank you for your reply. A bit more information for you, hopefully this will help. I am on a windows 2008 server and it has a SAN F drive attached to it. I am sending files from the F drive to a Linux box and After the successful copy of the file, i will get another copy on the C drive. Does WINSCP or the OS make copies of files while transmitting?
tx4
one other thing our shop uses SEP. Razz
I'm trying to rule out that WINSCP is the culprit of creating copies of the files i transmit.
WinSCP does not make any copies, except rare situation when downloading files in GUI to an external application using drag&drop. What is definitely not your case.
Post a session log file, if you need to debug this further.
