Topic "No border of active file row"
radist2s
If i select file row via keyboard then active row no have a dotted border like on screenshot below.
(This screenshot if found in internet to illustrate what i am talking about)
This rows selected via Ctrl + Click
This is row on hover.
This row selected via keyboard. Look at "Edit, Remove, Properties" toolbar. File is selected but row no have a dotted border.
I test this for all versions (5.1.7, 5.2.4b, 4.4) and for all version have same problem.
I tried change Windows color theme but problem persists. On my laptop is no such problem.
1) What version of Windows are you using?
2) Do you see the problem on other lists too? E.g. on Editor list in preferences dialog http://winscp.net/eng/docs/ui_pref_editor
3) Do you see focus rectangle on controls, such as buttons?
radist2s
Windows 7 x64 Ultimate
No, only in files list.
Yes, focus rectangle is present on buttons, etc. excluding file row.
Does the problem appear when you switch to Aero theme? Because you seem to use a classic theme. Are you?
radist2s
The problem is present on any theme with the switching on and off Aero.
Sorry, I've misunderstood you initial post.
Can you please post similar screenshots for WinSCP 4.4?
radist2s
On mouse click at file row.
On selecting same file via keyboard. (No border, no "clear selection", no file size, but rename, edit copy is present).
All themes, Air on or Air off.
Thanks. What about Find and Synchronization Checklist windows?
http://winscp.net/eng/docs/ui_find
http://winscp.net/eng/docs/ui_synchronize_checklist
Do you see the problem there?
