Topic "Cannot connect via SCP and command shell - via GUI it works"
Shiggysteve
Hi
I have the problem that I cannot connect to a device via the command shell.
in windows i open a command shell
winscp ENTER
open 168.10.1.61@root
I enter the correct password and then I usually get an error message:
Connection has been unexpectedly closes ...... Exit Status 127
When I turn on the logging everything is OK except for following line:
Using SFTP protocol (how do i tell it should use SCP)
and then following error is written there:
sh: /usr/libexec/sftp-server: not found
Please help
THx
Br
Stefan
Please attach a full log file showing the problem both for GUI and scripting session (using the latest version of WinSCP).
