Topic "Incorrect chars when upload files [SOLVED]"
leofire
Hi to all,
I'm trying to upload PHP file with this chars:
but when I reopen file I obtain this result:
"ì","é","è","ç","ò","°","#"," ","§","ù"
To fix this, at the moment, I need to edit file (double click on winscp remote screen), change manually this strange chars (for example "ì" and change to ""). When I save and reopen it I can see the correct chars.
There is a manner to fix this issue ?
Thanks in advance,
Leonardo
Try setting session settings UTF-8 Encoding for Filenames to On.
http://winscp.net/eng/docs/ui_login_environment#utf
Hi prikryl,
thanks for your suggestion. I have tried with different FTP account but any result.
I have change the option to UTF-8 to "attivo" (Active), I can login correctly but still anything... Sad
With this option you can upload the file correctly ?
Thanks in advance,
Leonardo
Could you try to upload this file and check it please ?
With other FTP client I can upload correctly.
Thanks in advance,
Leonardo
strange_chars.txt (189 Bytes) [Download]
Description: Strange Chars (rename to PHP and upload with Winscp)
Hi prikryl,
have you tried to upload this files ?
Everythign works fine for you ?
Leonardo
Sorry, I've misunderstood your problem.
Does this problem happen when you simply upload the file or when you open it in an editor (internal or external?) from WinSCP and save it?
Hi prikryl,
I just upload the files with ,, and when I open it (via shell or through winscp editor) I cannot see the correct chars.
Thanks for your help,
Leonardo
Your file is in UTF-8 encoding, but lacks BOM. WinSCP internal editor opens the file using ANSI encoding, when it lacks BOM, by default. You can switch to UTF-8 in the editor or make WinSCP default to UTF-8 in preferences:
http://winscp.net/eng/docs/ui_editor
http://winscp.net/eng/docs/ui_pref_editor
As for the shell: Your terminal client probably defaults to ANSI encoding too. It's also possibly that your host does not use UTF-8 encoding.
leofire
Hi prikryl,
thanks for your right suggest, you're great!
I have changed the editor to UTF8 and now I can see the correct chars when I use the
I have also added the header in PHP like this:
header('Content-Type: text/html; charset=utf-8');
and I can see all chars correctly!
If I try to use a str_replace in order to replace "" with "a" it works perfectly!
Probably vi from shell use the same encoding.
Many thanks for your suggest and have a good day,
Leonardo
