Topic "SSIS and Winscp"
Hi there,
I have a bit of an unusual issue when attempting to integrate winscp with SQL Server Integration Services
My preferred approach is to run the following :
WinSCP.exe /command "option batch abort" "option confirm off" "open sftp://#########:########@ftps.#####.com " "lcd \\######" "get PRD*"
"exit" -log="D:\WinSCP\Log\WinSCPCommandline.txt" -hostkey="###########"
However, this is failing with "The server's host key was not found in the cache"
What is strange though, is that when I run everything via a script, the process runs fine:
WinSCP.exe /script=D:\Data\Shell\WinSCP.txt /log=C:\Temp\WinSCPConf.txt
Contents of WinSCP.txt:
option batch abort
open sftp://#########:########@ftps.#####.com:22 -hostkey="###########"
lcd D:\#########
get PRD*
I have included the logs from both approaches.
Please can you assist.
LogScript.txt (5 KB) [Download]
Description: (none)
LogCommandLine.txt (4.98 KB) [Download]
Description: (none)
Please read FAQ:
http://winscp.net/eng/docs/faq_scheduler
If that does not help, come back.
