Topic "problem in script by winscp"
Mahdi Bashiri
Hi
i use below script to get all folders and files from my server to local hard disk inside specific path
winscp.com /command "option batch continue" "option confirm off" "open MyServer" "put / D:\Daily_Backup\yesterday\backup\vol\ "exit"
but after running i got this error:
C:\>winscp.com /command "option batch continue" "option confirm off" "open MyServer" "put / D:\Daily_Backup\yesterday\backup\vol\" "exit"
batch continue
confirm off
Connecting to MyServer ...
Connected with MyServer. Waiting for welcome message...
Connected
Starting the session...
Reading remote directory...
Session started.
Active session: [1] MyServer
/ | 0 KiB | 0.0 KiB/s | binary | 0%
Error creating folder '/vol/D:Daily_Backupyesterdaybackupvol/'.
Could not create directory "/vol/D:Daily_Backupyesterdaybackupvol"
i thought that i have mistake in synatx of command but i do not know where is my problem,please let me know and how can i fix that.
Regards,
Mahdi
I support you want to use get, instead of put.
Mahdi Bashiri
yes excuseme, i want to download (get)
please help me
So, did you try to replace the put with get? What is the error like now?
Mahdi Bashiri
so when i replaced , got below error:
C:\>winscp.com /command "option batch continue" "option confirm off" "open MyServer " "get / "D:\Daily_Backup\yesterday\backup\vol\"" "exit"
batch continue
confirm off
Connected
Session started.
Can't get attributes of file '/'.
File or folder '/' does not exist
And does your server have root folder (/)? E.g. if you login using GUI, can you browse all the way to the the root?
Mahdi Bashiri
Hi
myserver is novell netware server that ftp service is running. when connecting to myserver by winscp, shows "/sys/public" as first folder, so i change to remote directory in session to /vol and make /vol as root directory ( i d not know , does it correct").
therefore i use "/" as root because i make default remote directory as "/vol"
It does not work like that. You need to use /vol.
Mahdi Bashiri
my problem not solve
C:\>winscp.com /command "option batch continue" "option confirm off" "open MyServer" "get /vol "D:\Daily_Backup\vol\"" "exit"
batch continue
confirm off
Connected
Session started.
Can't get attributes of file '/vol'.
File or folder '/vol' does not exist.
Please attach a full log file showing the problem (using the latest version of WinSCP). Also attach a log showing how you browse into the /vol folder using GUI.
