Topic "Automatic Script requires manual intervention"
We are running scripts for downloading files on the daily basis. The IP addresses are for the straddles and the security features are not fixed - they are changed from time to time. When they are changed the scripts require manual intervention for updating the security information (Update/Ignore/Cancel/Abort). We would like to update the security options as automatic.
Please have a look sftp_conf.bat file and we have used the following commands:
option batch abort
option transfer binary
option batch continue
still it requires manual intervention for updating.
Please suggest us in this regard.
sftp_conf.bat (1.28 KB) [Download]
Description: Scripts file for automatic downloads
The latest beta version allows you to accept any SSH hostkey using open -hostkey=*:
Make sure you understand that you are losing any security by doing so.
That worked, Thanks
