Topic "Error opening session throug tunnel"
underdpt
I've a connection through a tunnel, that was working with previous release. After upgrading, If I try to use that connection it gives an error (details follow). Opening a session on the first server (the one that has to open the tunnel to the second one) works correctly.
Ask me if you need more info.
WinSCP 5.2.5
Invalid access to memory.
Using username "root".
Access denied.
Authentication failed.
underdpt
Hi Martin,
I've sent you an email as requested.
http://winscp.net/tracker/show_bug.cgi?id=1076
