Topic "Files with dots missing"
fsonnichsen
I have been using WinSCP for some time. Presently at version 5.1.7 b3446
I have some files on a remote server of the form xxx.yyy.zzz. I do not see these listed in the directory that WinSCP presents. All files without dots appear normally I believe the dot files have appeared in the past. I have looked through the labyrinth of winSCP menus and I don't see an option for suppressing files of this form (not to be confused with system files that begin with a dot).
Any ideas appreciated-
thanks
Fritz
I cannot generate the log file. I am running 5.17 and attempts to update indicate that this is the most recent release. The "logging" option does not appear at its place in the preferences menu for this version. (See attachments)
Fritz
Description: preferences menu
Description: release
Please use 5.2.5 beta for the test.
