Topic "Occasionally occuring problem with private/public key"
g24ftp
I have set up a scheduled process which connects automatically every hour to a proftpd server via sftp. I am authenticating with public/private key and it works fine like 98% of the time. But sometimes the server is refusing the key with the following error:
echo            on
option batch abort
batch           abort
confirm         off
option reconnecttime off
reconnecttime   off
option transfer binary
transfer        binary
open testuser@testserver.de
Searching for host...
Connecting to host...
Authenticating...
Using username "testuser".
Authenticating with public key "rsa-key-20131022".
Server refused public-key signature despite accepting key!
Password:
Connection has been unexpectedly closed. Server sent command exit status 0.
Here are the server logs:
Nov 04 23:04:04 mod_sftp/0.9.8[6620]: received client version 'SSH-2.0-WinSCP_release_5.1.7'
Nov 04 23:04:04 mod_sftp/0.9.8[6620]: handling connection from SSH2 client 'WinSCP_release_5.1.7'
Nov 04 23:04:04 mod_sftp/0.9.8[6620]:  + Session key exchange: diffie-hellman-group-exchange-sha1
Nov 04 23:04:04 mod_sftp/0.9.8[6620]:  + Session server hostkey: ssh-rsa
Nov 04 23:04:04 mod_sftp/0.9.8[6620]:  + Session client-to-server encryption: aes256-ctr
Nov 04 23:04:04 mod_sftp/0.9.8[6620]:  + Session server-to-client encryption: aes256-ctr
Nov 04 23:04:04 mod_sftp/0.9.8[6620]:  + Session client-to-server MAC: hmac-sha1
Nov 04 23:04:04 mod_sftp/0.9.8[6620]:  + Session server-to-client MAC: hmac-sha1
Nov 04 23:04:04 mod_sftp/0.9.8[6620]:  + Session client-to-server compression: none
Nov 04 23:04:04 mod_sftp/0.9.8[6620]:  + Session server-to-client compression: none
Nov 04 23:04:04 mod_sftp/0.9.8[6620]: sending acceptable userauth methods: password,publickey
Nov 04 23:04:04 mod_sftp/0.9.8[6620]: public key MD5 fingerprint: a1:b2:c3:d4:e5:f6:g7:h8:i9:j0:k1:l2:m3:n4:o5:p6
Nov 04 23:04:04 mod_sftp/0.9.8[6620]: sending publickey OK
Nov 04 23:04:04 mod_sftp/0.9.8[6620]: error verifying RSA signature:
Nov 04 23:04:04 mod_sftp/0.9.8[6620]: failed to verify 'ssh-rsa' signature on public key auth request for user 'testuser'
It seems like the problem only occurs with WinSCP Client. Similiar scripts with other clients are working fine
Is there a solution to this problem?
http://winscp.net/tracker/show_bug.cgi?id=1091
I've cc'd you on email to PuTTY team.
SG
Can you please confirm whether the following bug is fixed in the latest beta versions of WinSCP
I am using version 5.6.2 beta - which still has the Bug 1091.
There's no bug in WinSCP. It's a bug in ProFTPD server. If you are referring to a workaround for the server's bug implemented in WinSCP, it's included since 5.5.3. It predates any 5.6.x release, meaning all 5.6.x releases include the workaround too.
SG
Thanks Martin.
Is there way to use the workaround, and specify the "Requires Padding on SSH-2 RSA Signatures" in automation (winscp.com)?
You have the workaround enabled automatically in 5.6.2 beta. Enabling it explicitly won't change anything.
Anyway, to do that use: open user@host -rawsettings BugRSAPad2=2
