Topic "COM library putFiles giving error on VBA"
PeBoe
Hi
I'm trying to use the COM object in VBA; after successful creation and initialization of a session object which I call m_session I try:
transferResult = m_session.putFiles(localPath, remotePath)
also tried:
set transferResult = m_session.putFiles(localPath, remotePath)
But I always get an Error: "object reference not set to an instance of an object"
NOTE: I know m_session is OK, because when using it with m_session.ExecuteCommand('any UNIX cmd') it works fine
Working with:
Microsoft Windows XP Professional; Version 5.1.2600 Service Pack 3 Build 2600
Microsoft Visual Basic 6.5
WinSCP 5.1.7
WinSCP COM Assemmbly 5.1.7
Thanks for your help
PeBoe
Your code works for me in VBA 7.0 (Excel 2010). Are you using VBA or VB?
PeBoe
I'm working with Excel 2003 SP3
PeBoe
Sorry, forgot to add: using VBA
I would not expect this to differ between 2003 and 2010.
Anyway, can you post your complete code?
PeBoe
Sorry Martin
after further playing around with my example code I discovered my error (an uninitialized variable within my method); as often, just a copy/paste error Evil or Very Mad
After the small correction, the code runs perfectly !
Thanks a lot for your efficient support Very Happy
Friendly regards
P.Boehm
