Topic "Sass Compiling with --watch"
mikestreety
This is a bit of a random one, and i'm not sure which side this lies - because of that i'm making both parties aware in the hope we can get somewhere.
WinSCP version 5.2.5 (but also happens on older ones)
I am using WinSCP to transfer files to a local server running CentOS via SFTP (also happens over SCP).
In a terminal window, I am running
sass --watch
- this compiles sass files into css when they are updated. If you don't know about sass, its a CSS Prepocessor.
After uploading the file the first time, the watch script detects that there is a change and compiles the sass, however, every time after that it simply detects and change and doesn't compile.
The reason I am posting this here is because it only happens with WinSCP. Using the same protocol on the same sever with the same files but with a different SFTP/SCP program, the files compile correctly on every upload.
I apologise for the vagueness of the post - being quite bespoke, I struggled to fulfill all the criteria in the link.
There is my Sass bug report on Github.
An environment when command is run from WinSCP is different than your regular terminal environment. Particularly, some environment variable are removed. Also the session does not have TTY, what among other means that different startup scripts are called. All this can have impact on your build scripts.
mikestreety
Ah sorry - realised there are some crossed wires.
sass --watch is run in a separate terminal application (putty) connected to the same server.
Ok. It can be a problem with timestamps. Check that, after your upload files with WinsCP, the timestamps are not in the past (earlier then previous build).
mikestreety
Ah you genius!
Seems when I upload, the timestamp is that of my computer, but compiling it uses the server time.
Interesting - thanks!
