Topic "WinSCP FTP+SSL"
DJAnonimo
i have a problem with listing and I would like to avoid it by using a "STAT -l" listing command but I do not see where to set the listing command like in FTPRush.
Anyone can help?
Thank You
Pathduck
Hello - does this help?
http://winscp.net/eng/docs/ui_login_ftp
You can set the command to use for directory listing:
Quote:
The Use MLSD command for directory listing controls, if WinSCP uses MLSD or (deprecated) LIST command for directory listing. When set to Auto (preferred), WinSCP decides based on accounced features of FTP servers. Use Off only, if servers implementation of MLSD command has bugs. This feature is available only in the latest beta release. In the latest stable version, this option is configurable using session raw settings.
However, for FTP it is limited to either MLSD or LIST obviously, for SCP you can set the actual listing command.
Personally, I would use the Terminal when having problems listing, but it does not work with FTP either.
DJAnonimo
I do not see any listing commands when on FTP + SSL inplicit.
Where I should look?
Pathduck
Like the doc states, this is only a feature in the latest beta:
http://winscp.net/eng/download.php
It's not a feature for SFTP so I guess this is not an issue there.
Hope it works.
DJAnonimo
Thank You for fast answering.
What kind of problem?
