Topic "drag and drop"
IrvingW
Hi
I am having a problem with Drag & Drop that I have not found on the FAQ or search queries. Occasionally, the WinSCP refuses to do anything when I do the drag and drop function. Nothing changes in the log file. I am running Windows XP Professional, and using the latest version of WinSCP. This problem occurred with an earlier version of WinSCP also. I generally can fix the problem by rebooting, but that is obviously not the best solution. I am using SFTP (v. 3). I am including a copy of the log file.
Thank you. (INweinberg@aol.com)
WinSCP Version 3.6.1 (Build 221) (OS 5.1.2600 Service Pack 1)
Login time: Thursday, May 20, 2004 1:45:57 PM
Session name: weinberg@www.naviscan.org
Host name: www.naviscan.org (Port: 22)
User name: weinberg (Password: Yes, Key file: No)
Transfer Protocol: SFTP (SCP)
SSH protocol version: 2; Compression: No
Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
SSH Bugs:
Proxy: none
Return code variable: Autodetect; Lookup user groups: Yes
Shell: default, EOL: 0
Local directory: default, Remote directory: home, Update: No, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
Looking up host "www.naviscan.org"
Connecting to 66.237.217.162 port 22
Server version: SSH-1.99-OpenSSH_3.5p1
We claim version: SSH-2.0-WinSCP-release-3.6.1
Using SSH protocol version 2
Doing Diffie-Hellman group exchange
Doing Diffie-Hellman key exchange
Host key fingerprint is:
ssh-rsa 1024 9f:84:2f:de:b4:f1:0b:d8:1a:3a:7c:4e:f0:69:e5:be
Initialised AES-256 client->server encryption
Initialised AES-256 server->client encryption
Using username "weinberg".
Keyboard-interactive authentication refused
Session password prompt (weinberg@www.naviscan.org's password: )
Using stored password.
Sent password
Access granted
Opened channel for session
Started a shell/command
Using SFTP protocol.
Doing startup conversation with host.
Type: SSH_FXP_INIT, Size: 5, Number: -1
Type: SSH_FXP_VERSION, Size: 5, Number: -1
SFTP version 3 negotiated.
Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
Type: SSH_FXP_STATUS, Size: 38, Number: 200
Status/error code: 8
Server does not recognise WinSCP.
Getting current directory name.
Getting real path for '.'
Type: SSH_FXP_REALPATH, Size: 10, Number: 528
Type: SSH_FXP_NAME, Size: 49, Number: 528
Real path is '/home/weinberg'
Listing directory "/home/weinberg".
Type: SSH_FXP_OPENDIR, Size: 23, Number: 779
Type: SSH_FXP_HANDLE, Size: 13, Number: 779
Type: SSH_FXP_READDIR, Size: 13, Number: 1036
Type: SSH_FXP_NAME, Size: 1337, Number: 1036
Type: SSH_FXP_READDIR, Size: 13, Number: 1292
Type: SSH_FXP_STATUS, Size: 28, Number: 1292
Status/error code: 1
Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
Type: SSH_FXP_STATUS, Size: 24, Number: 1540
Status/error code: 0
Startup conversation with host finished.
Changing directory to "..".
Getting real path for '/home/weinberg/..'
Type: SSH_FXP_REALPATH, Size: 26, Number: 1808
Type: SSH_FXP_NAME, Size: 31, Number: 1808
Real path is '/home'
Trying to open directory "/home".
Type: SSH_FXP_OPENDIR, Size: 14, Number: 2059
Type: SSH_FXP_HANDLE, Size: 13, Number: 2059
Type: SSH_FXP_CLOSE, Size: 13, Number: 2308
Type: SSH_FXP_STATUS, Size: 24, Number: 2308
Listing directory "/home".
Type: SSH_FXP_OPENDIR, Size: 14, Number: 2571
Type: SSH_FXP_HANDLE, Size: 13, Number: 2571
Type: SSH_FXP_READDIR, Size: 13, Number: 2828
Type: SSH_FXP_NAME, Size: 1305, Number: 2828
Type: SSH_FXP_READDIR, Size: 13, Number: 3084
Type: SSH_FXP_STATUS, Size: 28, Number: 3084
Type: SSH_FXP_CLOSE, Size: 13, Number: 3332
Type: SSH_FXP_STATUS, Size: 24, Number: 3332
Getting real path for '/home/..'
Type: SSH_FXP_REALPATH, Size: 17, Number: 3600
Type: SSH_FXP_NAME, Size: 23, Number: 3600
Real path is '/'
Trying to open directory "/".
Type: SSH_FXP_OPENDIR, Size: 10, Number: 3851
Type: SSH_FXP_HANDLE, Size: 13, Number: 3851
Type: SSH_FXP_CLOSE, Size: 13, Number: 4100
Type: SSH_FXP_STATUS, Size: 24, Number: 4100
Listing directory "/".
Type: SSH_FXP_OPENDIR, Size: 10, Number: 4363
Type: SSH_FXP_HANDLE, Size: 13, Number: 4363
Type: SSH_FXP_READDIR, Size: 13, Number: 4620
Type: SSH_FXP_NAME, Size: 2873, Number: 4620
Type: SSH_FXP_READDIR, Size: 13, Number: 4876
Reading symlink "tmp".
Type: SSH_FXP_READLINK, Size: 13, Number: 5139
Type: SSH_FXP_STAT, Size: 13, Number: 5393
Type: SSH_FXP_STATUS, Size: 28, Number: 4876
Type: SSH_FXP_NAME, Size: 45, Number: 5139
Type: SSH_FXP_ATTRS, Size: 37, Number: 5393
Type: SSH_FXP_CLOSE, Size: 13, Number: 5636
Type: SSH_FXP_STATUS, Size: 24, Number: 5636
Changing directory to "usr".
Getting real path for '/usr'
Type: SSH_FXP_REALPATH, Size: 13, Number: 5904
Type: SSH_FXP_NAME, Size: 29, Number: 5904
Real path is '/usr'
Trying to open directory "/usr".
Type: SSH_FXP_OPENDIR, Size: 13, Number: 6155
Type: SSH_FXP_HANDLE, Size: 13, Number: 6155
Type: SSH_FXP_CLOSE, Size: 13, Number: 6404
Type: SSH_FXP_STATUS, Size: 24, Number: 6404
Listing directory "/usr".
Type: SSH_FXP_OPENDIR, Size: 13, Number: 6667
Type: SSH_FXP_HANDLE, Size: 13, Number: 6667
Type: SSH_FXP_READDIR, Size: 13, Number: 6924
Type: SSH_FXP_NAME, Size: 2105, Number: 6924
Type: SSH_FXP_READDIR, Size: 13, Number: 7180
Reading symlink "local".
Type: SSH_FXP_READLINK, Size: 19, Number: 7443
Type: SSH_FXP_STAT, Size: 19, Number: 7697
Type: SSH_FXP_STATUS, Size: 28, Number: 7180
Type: SSH_FXP_NAME, Size: 51, Number: 7443
Type: SSH_FXP_ATTRS, Size: 37, Number: 7697
Type: SSH_FXP_READLINK, Size: 17, Number: 7955
Type: SSH_FXP_STAT, Size: 17, Number: 8209
Type: SSH_FXP_NAME, Size: 41, Number: 7955
Type: SSH_FXP_ATTRS, Size: 37, Number: 8209
Type: SSH_FXP_CLOSE, Size: 13, Number: 8452
Type: SSH_FXP_STATUS, Size: 24, Number: 8452
Changing directory to "local".
Getting real path for '/usr/local'
Type: SSH_FXP_REALPATH, Size: 19, Number: 8720
Type: SSH_FXP_NAME, Size: 51, Number: 8720
Real path is '/data/usr/local'
Trying to open directory "/data/usr/local".
Type: SSH_FXP_OPENDIR, Size: 24, Number: 8971
Type: SSH_FXP_HANDLE, Size: 13, Number: 8971
Type: SSH_FXP_CLOSE, Size: 13, Number: 9220
Type: SSH_FXP_STATUS, Size: 24, Number: 9220
Listing directory "/data/usr/local".
Type: SSH_FXP_OPENDIR, Size: 24, Number: 9483
Type: SSH_FXP_HANDLE, Size: 13, Number: 9483
Type: SSH_FXP_READDIR, Size: 13, Number: 9740
Type: SSH_FXP_NAME, Size: 2155, Number: 9740
Type: SSH_FXP_READDIR, Size: 13, Number: 9996
Type: SSH_FXP_STATUS, Size: 28, Number: 9996
Type: SSH_FXP_CLOSE, Size: 13, Number: 10244
Type: SSH_FXP_STATUS, Size: 24, Number: 10244
Changing directory to "apache2".
Getting real path for '/data/usr/local/apache2'
Type: SSH_FXP_REALPATH, Size: 32, Number: 10512
Type: SSH_FXP_NAME, Size: 67, Number: 10512
Real path is '/data/usr/local/apache2'
Trying to open directory "/data/usr/local/apache2".
Type: SSH_FXP_OPENDIR, Size: 32, Number: 10763
Type: SSH_FXP_HANDLE, Size: 13, Number: 10763
Type: SSH_FXP_CLOSE, Size: 13, Number: 11012
Type: SSH_FXP_STATUS, Size: 24, Number: 11012
Listing directory "/data/usr/local/apache2".
Type: SSH_FXP_OPENDIR, Size: 32, Number: 11275
Type: SSH_FXP_HANDLE, Size: 13, Number: 11275
Type: SSH_FXP_READDIR, Size: 13, Number: 11532
Type: SSH_FXP_NAME, Size: 1937, Number: 11532
Type: SSH_FXP_READDIR, Size: 13, Number: 11788
Type: SSH_FXP_STATUS, Size: 28, Number: 11788
Type: SSH_FXP_CLOSE, Size: 13, Number: 12036
Type: SSH_FXP_STATUS, Size: 24, Number: 12036
Changing directory to "htdocs".
Getting real path for '/data/usr/local/apache2/htdocs'
Type: SSH_FXP_REALPATH, Size: 39, Number: 12304
Type: SSH_FXP_NAME, Size: 81, Number: 12304
Real path is '/data/usr/local/apache2/htdocs'
Trying to open directory "/data/usr/local/apache2/htdocs".
Type: SSH_FXP_OPENDIR, Size: 39, Number: 12555
Type: SSH_FXP_HANDLE, Size: 13, Number: 12555
Type: SSH_FXP_CLOSE, Size: 13, Number: 12804
Type: SSH_FXP_STATUS, Size: 24, Number: 12804
Listing directory "/data/usr/local/apache2/htdocs".
Type: SSH_FXP_OPENDIR, Size: 39, Number: 13067
Type: SSH_FXP_HANDLE, Size: 13, Number: 13067
Type: SSH_FXP_READDIR, Size: 13, Number: 13324
Type: SSH_FXP_NAME, Size: 6539, Number: 13324
Type: SSH_FXP_READDIR, Size: 13, Number: 13580
Type: SSH_FXP_STATUS, Size: 28, Number: 13580
Type: SSH_FXP_CLOSE, Size: 13, Number: 13828
Type: SSH_FXP_STATUS, Size: 24, Number: 13828
Changing directory to "irving".
Getting real path for '/data/usr/local/apache2/htdocs/irving'
Type: SSH_FXP_REALPATH, Size: 46, Number: 14096
Type: SSH_FXP_NAME, Size: 95, Number: 14096
Real path is '/data/usr/local/apache2/htdocs/irving'
Trying to open directory "/data/usr/local/apache2/htdocs/irving".
Type: SSH_FXP_OPENDIR, Size: 46, Number: 14347
Type: SSH_FXP_HANDLE, Size: 13, Number: 14347
Type: SSH_FXP_CLOSE, Size: 13, Number: 14596
Type: SSH_FXP_STATUS, Size: 24, Number: 14596
Listing directory "/data/usr/local/apache2/htdocs/irving".
Type: SSH_FXP_OPENDIR, Size: 46, Number: 14859
Type: SSH_FXP_HANDLE, Size: 13, Number: 14859
Type: SSH_FXP_READDIR, Size: 13, Number: 15116
Type: SSH_FXP_NAME, Size: 13665, Number: 15116
Type: SSH_FXP_READDIR, Size: 13, Number: 15372
Type: SSH_FXP_NAME, Size: 13647, Number: 15372
Type: SSH_FXP_READDIR, Size: 13, Number: 15628
Type: SSH_FXP_NAME, Size: 2593, Number: 15628
Type: SSH_FXP_READDIR, Size: 13, Number: 15884
Type: SSH_FXP_STATUS, Size: 28, Number: 15884
Type: SSH_FXP_CLOSE, Size: 13, Number: 16132
Type: SSH_FXP_STATUS, Size: 24, Number: 16132
Changing directory to "aclin".
Getting real path for '/data/usr/local/apache2/htdocs/irving/aclin'
Type: SSH_FXP_REALPATH, Size: 52, Number: 16400
Type: SSH_FXP_NAME, Size: 107, Number: 16400
Real path is '/data/usr/local/apache2/htdocs/irving/aclin'
Trying to open directory "/data/usr/local/apache2/htdocs/irving/aclin".
Type: SSH_FXP_OPENDIR, Size: 52, Number: 16651
Type: SSH_FXP_HANDLE, Size: 13, Number: 16651
Type: SSH_FXP_CLOSE, Size: 13, Number: 16900
Type: SSH_FXP_STATUS, Size: 24, Number: 16900
Listing directory "/data/usr/local/apache2/htdocs/irving/aclin".
Type: SSH_FXP_OPENDIR, Size: 52, Number: 17163
Type: SSH_FXP_HANDLE, Size: 13, Number: 17163
Type: SSH_FXP_READDIR, Size: 13, Number: 17420
Type: SSH_FXP_NAME, Size: 1127, Number: 17420
Type: SSH_FXP_READDIR, Size: 13, Number: 17676
Type: SSH_FXP_STATUS, Size: 28, Number: 17676
Type: SSH_FXP_CLOSE, Size: 13, Number: 17924
Type: SSH_FXP_STATUS, Size: 24, Number: 17924
Where do you drag from and to? Does it matter?
What exactly happens? Nothing at all, some error message (what), ...?
If you drag from remote directory in WinSCP to Windows Explorer (or desktop), and you have installed WinSCP drag&drop shell extension, you may try to enable its debugging and send me a log file.
To do so, save following code to .reg file and import it to Windows registry. Of course, modify the "LogFile" to point to path, where you can write to (do not forget to double the backslashes).
REGEDIT4
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\DragExt]
"Enable"=dword:00000001
"LogFile"="c:\\dragext.log"
I've forgot to add that after importing the .reg file, you need to restart your computer (or at least log off/on).
