Topic "Powershell & transferresumesupport in .net/beta version"
paolop
maybe somebody will be so kind as to help me out.
I'm trying to run a PS script to upload (large) backup files to a Gluster node. It seems I can't turn off the creation of temporary files on the target, and this causes problems with Gluster locking/replicating the 'filepart' files.
Can anybody suggest what I might be doing wrong? (I'm not a scripting guy, please forgive stupid mistakes)
Here are the relevant lines in the script...
[Reflection.Assembly]::LoadFrom("c:\program files (x86)\winscp\WinSCPnet.dll") | Out-Null
$sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
$transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::Off
$transferResult = $session.PutFiles($fullfilename, $remotePath, $transferOptions)
I also tried setting TransferResumeSupportState to ::Smart and setting a Threshold of 10000000 (10 G), but it does not work either (is threshold a 16-bit integer or a 32-bit integer?)
Any idea what I am doing wrong?
Thanks!
options is fourth parameter of Session.PutFiles, while you pass it to third parameter, what is remove.
http://winscp.net/eng/docs/library_session_putfiles
paolop
...don't know what to say.... DHU! (you do not have a face palm emoticon)
Thanks....
