Topic "Help with Winscp.dll installation"
sarathicse
I am trying the below C# example in Visual Studio
http://winscp.net/eng/docs/library_session_getfiles#example
But it gives me Error
The type or namespace name 'WinSCP' could not be found (are you missing a using directive or an assembly reference?) C:\Users\sarathik\Desktop\SFTP Test\SFTP Test WinSCP\SFTP Test WinSCP\Program.cs 4 7 SFTP Test WinSCP
I am using 5.1.7 WinSCP.
I downloaded the .NET component and extracted it in C:\Program Files (x86)\WinSCP folder
I used the following command for registering the component %WINDIR%\Microsoft.NET\Framework64\v4.0.30319\RegAsm.exe WinSCP.dll /codebase /tlb
It registered.
But even still the program shows the namespace is not available.
What am i doing wrong here. Is there a way to verify if the dll is loaded correctly.
Should i need to copy it somewhere to get this working?
Sarathi.
Have you tried to debug this with Fuslogvw.exe?
https://msdn.microsoft.com/en-us/library/e74a18c4.aspx
Attach Fuslogvw.exe log file if you need further help.
sarathicse
prikryl,
I will check on this and will update the status.......
Sarathi.
