Topic "Monospace font for 'server prompt' window?"
Some server I want to connect to use a ASCII-based CAPTCHA <http://www.semicomplete.com/projects/pam_captcha/>. This workd fine with tools like ssh and putty. However WinSCP uses a non-monospace font which screws up the CAPTHA. Is it possible to use a monospace font in the 'server prompt' window to fix this? Thanks in advance!
Cheers,
Jeroen
Description: putty versus winscp
I would not like to make monospace font default. But it can be optional. Or WinSCP can try to autodetect need to use monospace font somehow.
Any chance of getting a test account on your server?
All sound good to me...
Unfortunately access to a production server is not possible. Setup on Ubuntu, on a root prompt:
wget <invalid hyperlink removed by admin>
cd /opt
tar xfz /tmp/pam_captcha-1.5.tar.gz
apt-get install libpam0g-dev
apt-get install figlet
make
cp pam_captcha.so /lib/security/.
vim /etc/pam.d/sshd
--> add first line
auth requisite pam_captcha.so math dda randomstring
vim /etc/ssh/sshd_config
--> add / unremark
PasswordAuthentication no
ChallengeResponseAuthentication yes
If this is not working for you, please let me know and I'll setup a test VM.
Cheers,
Jeroen
Missed one line:
cd /opt
make
vim /etc/pam.d/sshd
--&amp;gt; add first line
--&amp;gt; add / unremark
That would be great!
Inuya5ha
Now that we are on the fonts topic, the Enter Command text box from the Console window should use a monospace font as well, just like the log window which is now using Lucida Console.
Thanks for your suggestion. Will see if more people ask for it.
ADTC
Until this feature is added, a simple workaround would be to copy the text to Notepad or something monospaced Smile Assuming that you can actually copy it from the WinSCP window, of course.
g.synedra
i second that monospaced font should be used in the server prompt.
we use figlet inside our banners and those get mixed up as well.
This request has been added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=1153
