Topic "getting the remote directory listing into a local file"
sy27295
Suppose I login with this
"C:\Program Files (x86)\WinSCP\WinSCP.com" /command "option batch abort" "option confirm off" "open sftp://UserName:Password@site.sftpSite.com"
what next command can get the directory into a local file
winscp>dir e:\data\dir.txt
or
winscp>dir > e:\data\dir.txt
or, can it be something like this
"C:\Program Files (x86)\WinSCP\WinSCP.com" /command "option batch abort" "option confirm off" "open sftp://UserName:Password@site.sftpSite.com" "cd \OUT" "dir e:\data\dir.txt"
Should it be \console or \command
sy27295
NOT WORKING ..... in command line
or
or
You cannot redirect an individual script commands to a file. You can:
- Redirect whole WinSCP output to a file: winscp.com /command ... > out.txt
- Redirect remote command to a remote file and download it: call ls > out.txt and get out.txt
- Enable XML logging and parse the listing out of the XML log:
http://winscp.net/eng/docs/logging_xml
