Topic "Handle new files after sync"
halycon
Hey guys,
i'm syncing a remote ftp dir to my local drive. My target is to handle all NEW synced files.
At the moment i'm using a batch file, which takes the "newest file" and does something to it:
for /f "delims=" %%a in ('dir /a-d /b /od *.zip') do set "newest=%%a"
The problem is: if there are e.g. two or three new files since the last sync, the batch only takes the newest file.
I thought about do xml logging and parse it to some python code or something to compare "before-sync <-> after-sync" and find out the filenames of the newest files. But i don't get it.
Is there any more easy way? Do you have any hint?
Thanks in advance...
I do not think there's any easier solution.
But I believe that if you take this PowerShell example and just modify FileTransferred function to do what you need, it should be pretty easy:
http://winscp.net/eng/docs/library_session_synchronizedirectories#powershell
halycon
Thanks for your reply!
I just finished my python script for this problem and tested it succesfully.
Maybe somebody will be interested in such a thing in the future so i post it here: (it was my very first attempt to write python code! i hope it's not a shame Mr. Green)
import shutil
import xml.etree.ElementTree as ET
import os
syncdir = "k:\\sync"        #these are some
updatedir = "k:\\"        #directories
workingdir= "d:\\bue_update\\"        #i'm working with
winscp_lsxml = "d:\\bue_update\\winscp\\winscp.com /script=ls_xml.winscp /xmllog=xmllog.xml"  #this puts me a list of remote filenames into a xml
winscp_sync = "d:\\bue_update\\winscp\\winscp.com /script=sync_local.winscp"                  #this syncs so i can take the files
update_batch = updatedir+"\\ohnepause.bat"
os.system("connect_shares.bat")
os.system(winscp_lsxml)
os.system(winscp_sync)
newlog = ET.parse('xmllog.xml') #parses the fresh log from the os.system(winscp_lsxml) command
lastlog = ET.parse('last_xmllog.xml')   #parses the log from the lasttime os.system(winscp_lsxml) command
root = newlog.getroot()
namespace = "{http://winscp.net/schema/session/1.0}"
filenames = root.findall('{0}ls/{0}files/{0}file/{0}filename'.format(namespace))
liste = []
for namen in filenames:
    if "universal-lsb-rest-client" in namen.get('value'):     #i dont't want this file
        continue
    elif ".zip" in namen.get('value'):                        #put all *.zip filenames in my list
        liste.append(namen.get('value'))
for i in liste:
    print(i)
print("Anzahl Elemente xmllog",liste.__len__())
last_root = lastlog.getroot()
last_filenames = last_root.findall('{0}ls/{0}files/{0}file/{0}filename'.format(namespace))
last_liste = []
for namen in last_filenames:
        last_liste.append(namen.get('value'))            #and make me a list of the lasttime log so i can compare
for i in last_liste:
    print(i)
print("Anzahl Elemente last_xmllog",last_liste.__len__())
print("Vergleiche Listen...")
for namen in liste:
    if namen not in last_liste:                                                             #here i compare the lists
        print(namen)
        cmd = workingdir + "7za.exe e " + syncdir + "\\" + namen+" -o"+updatedir+" -y"      #and extract all files
        print(cmd)
        os.system(cmd)
shutil.copy("xmllog.xml","last_xmllog.xml")                                        #save the fresh log for the next run
os.system(update_batch)
#os.system("disconnect_shares.bat")
Thanks for sharing your solution.
