Topic "Visual improvement suggestion for a prompt dialog"
oliverfr
I thought all was fine, and this morning, twice, I found myself interrupting an existing transfer, and relaunching it again, because I realized I wasn't sure about what I had chosen.
Looked like a field for easy improvement Smile
So, I humbly submit this improvement suggestion, rather than writing a wall of text, I used photoshop. Merry holidays to everyone, while I'm here ! Smile
Description: In my eyes, that kind of menu would make much more sense, it doesn't ask the brain to work as hard, and "goes with the flow" of intuition and common sense.
Description: the current dialog. Confusing, counter-intuitive. Important information stacked in odd places.
Microsoft Dialog Boxes guidelines suggest that generic Yes/No button should be used, if you want user to read the question carefully (e.g. to avoid him loosing data). With this question, it not easy to decide if it is the case or not. I'll think about it.
https://msdn.microsoft.com/en-us/library/windows/desktop/dn742499.aspx
oliverfr
Just saw the new dialogue in the 5.5.0 version : GREAT JOB ! Smile
oliverfr
Hmm, replying to myself, to bump the thread. I just saw there was a very important option/action combo missing.
Option : comparing remote and local files by size. Identical size, or not.
Action : skip, resume or overwrite.
As things are, if we had to turn our PC in the middle of a HUGE series of uploads, and want to resume the day after, we can't re- drag and drop everything to the remote server, and simply tell the program "look at the file sizes, skip what's already complete, overwrite what's incomplete, and proceed with the rest".
That's very specific request that would not have widespread use. Moreover you can achieve this using synchronization.
