Topic "5.5: Suggestion for dropdown "save as" dialog"
Pathduck
Hello Martin Smile
I have a suggestion for the dropdown dialogs in the new session management interface.
Here's my problem, I do this a lot:
- Select existing session, often in a folder
- Choose Edit and change hostname.
- Choose Save As and change just the name of session (user@hostname), so the folder is the same.
This behaviour is different from the "Clone" option since it lets you save in the same folder as the old session. I have a lot of folders and sessions for different environment and do this quite a lot so am dependent on a quick way of doing it using the keyboard.
My suggestion:
- Change shortcut for "Save As..." to ALT+A, which is consistent with standard Windows conventions.
- Change shortcut for "Advanced" to ALT+D, which is also pretty logical and should not interfere with other commands.
This way, I could quickly choose Save As when finished editing a new session.
Hope you can have a look at this, and wishing you all the best for the holidays and a Happy New Year! Smile
-Stian
Thanks for your suggestions. Will do.
Also the Clone command may actually remember the folder (and even site name).
All implemented.
Your requests added to tracker:
http://winscp.net/tracker/show_bug.cgi?id=1106
http://winscp.net/tracker/show_bug.cgi?id=1105
For complete list of changes:
http://winscp.net/eng/docs/history#5.5.1
Will send you dev version for testing shortly.
Pathduck
Wow, that was fast Shocked
Thanks a lot Martin, tried the dev build, works like a charm Smile
It will be much easier to do this stuff with the keyboard shortcuts now.
cheers,
Stian
Leora45
Niiiice ! I was just about to create a thread to ask for this improvement !
Thanks for the so fast implementation Wink
Leora
I have sent you a download link via email too.
Leora45
Thanks ! Smile
