Topic "Query with a simple get script"
Chris_Tarris
Hi there, I am having trouble getting a simple script to run.
Running WinSCP version 5.5.0 (Build 3839) Commander interface on Windows 7. Transfer protocol is SFTP, trying to get a script to run manually.
My .bat file is:
@echo off
winscp.exe /console /script=script.txt
My script.txt is in the same directory as the .bat:
option batch abort
open sftp://user:pass@00.000.000.00
get ""/Email Attachments/File_1.csv"" .\
(I have wrapped the remote path in double quotes due to the space in the folder name.)
When I run the .bat file, the file is not retrieved - nor does anything show up in the log window.
I'm wondering if I've missed a step somewhere.
Thank you in advance for any help you can provide!
Kind regards
Chris
Chris_Tarris
[I didn't register before posting. Adding this reply to receive email notifications. Thanks.]
Chris_Tarris
I read a few more forum posts and realised I needed to run the script in the same folder as the .exe. Sorry! Thank you.
Also:
1) You should better use winscp.com to avoid additional console window popup for winscp.exe.
2) You should use only single double quotes: get "/Email Attachments/File_1.csv" .\
