Topic ""Copy Link Location""
I would like to be able to pick a file in a WinSCP window, right click and pick "Copy Link Location" and on my clipboard I would get a link like
sftp://somehost.com/dir/to/a/file.txt
So that I may paste that in an email and have others who have winSCP be able to click that and get it to load up.
myers
You can copy path to file (not URL) to clipboard. See File(s) menu.
Anyway WinSCP cannot handle URLs pointing to file yet, so even if you mail the URL, the others would be able just to click it to get it.
I am sorr about the above.
It would like to be able to use perl or php regular expressions.
&PATH= home/user/public_html/file.jpg
&SEVER=somedomain.com
Required URL
http://somedomain.com/user/file.jp
Then if were were allowed to write a php expression
Click to link:
"http://".$SERVER.str_replace("home/user/public_html", "/~user", &PATH)
then it would be really great and time saving.
Tim
I guess you can implement what you ask for using custom command feature (see Preferences/Commands).
Add new 'remote' command like:
echo '<?="http://somedomain.com".str_replace("home/'`whoami`'/public_html", "~'`whoami`'", "'`pwd`'")."/!\n"?>' | php -q
and check 'show results in terminal' and 'apply to directories'.
The exclamation mark (!) will be replaced with name of file selected in the panel.
Note that the option 'show results in terminal' is new in yesterdays release 3.7
