Topic "Parse remote file names without downloading first?"
robbielj
Is there any way I can parse remote selected file name(s) into a customized local command without downloading selected file(s) first?
I need to feed a local script with remote file info as command line arguments. No download is actually needed.
Also it seems to me that remote port pattern is not available.
Thanks.
You can extract remote directory listing from XML log:
http://winscp.net/eng/docs/logging_xml
Or use Session.ListDirectory from WinSCP .NET assembly:
http://winscp.net/eng/docs/library_session_listdirectory
