Topic "Error: File opened in browser doesn't exist"
Petr Svatoň
Hi, I'm using WinSCP version 5.5.0 Build 3839. I found a bug when using the connection tabs. When you have multiple connections, on one of them open some text file in browser (via F4) and let it open. Then switch to another connection and try to refresh the browser (I'm using this small green icon on the toolbar). You get an error that file doesn't exist on the server. But when you return to the according tab, it works again. Seems to me the browser should use the according connection and not the focused one.
Thanks, Petr
This bug is being tracked already:
http://winscp.net/tracker/show_bug.cgi?id=603
