Topic "I cannot find the properties dialog"
konstantinos
Location: Athens, Greece, Altitude: 158 m, Density Altitude: 675 m.
Hello all. I cannot find where exactly is the properties dialog: http://winscp.net/eng/docs/ui_properties
Can you help me? For example, if I go to running WinSCP, right click in a file, and then properties, it shows me the windows properties (About folder: General, Sharing, Security, Previous Versions, Customize). The same if I go in the files and then properties.
Any help?
konstantinos
I just found the solution alone. You have to look in the right side of Commander Interface, not in the left one. http://winscp.net/eng/docs/interfaces#changing_user_interfaces
I uploaded my file from the left side to my host and I find the properties dialog of it in the right side.
