Topic "Errorevent Running .NET-Powershellscript in Sched-Tasks"
lellerkamp
Dear Sir or Maddam,
I'm using the .NET assembly in Powershellscript to exchange files between a Windows Server 2008R2 an 2 Unix machines via SCP/SFTP.
First I get the files from a Unix machine to W2k8R2 via SCP. Later they will be putted on a HP-UX machine via SFTP.
If I run the script manually, the script completes without any errors. If I run the script via Scheduled Tasks (The local admin is defined to run the task), a error will be created in Event Viewers Queue "Application" -look for Error below-.
In both cases, the filetransfer works great, so I don't know why the error is shown.
Queue: Application
Source: Application Error
Name der fehlerhaften Anwendung: winscp.exe, Version: 5.5.0.3839, Zeitstempel: 0x00000000
Name des fehlerhaften Moduls: winscp.exe, Version: 5.5.0.3839, Zeitstempel: 0x00000000
Ausnahmecode: 0xc0000005
Fehleroffset: 0x002bf2a0
ID des fehlerhaften Prozesses: 0xb88
Startzeit der fehlerhaften Anwendung: 0x01cf141a050e0306
Pfad der fehlerhaften Anwendung: C:\Program Files\WinSCP\winscp.exe
Pfad des fehlerhaften Moduls: C:\Program Files\WinSCP\winscp.exe
Berichtskennung: 4382d468-800d-11e3-8497-00155d8e1904
I didn't found any troubleshooting information. It would be great, if I get help asap.
L. Ellerkamp
lellerkamp
The problem is solved Very Happy
In the script, I've opened the connection some times, but I've not closed the session.
In TaskManager WinSCP.exe is running many times.
I dispose the session now at the end of the script and anything works great.
Martin, thanks for your fast reply.
