Administrator rights for installer
MartinPokorny
When I downloaded the installer for version 5.5.1 (build 3970) from https://winscp.net/download/winscp551setup.exe/download the installer could not update my application since WinSCP is installed in Program Files and only Admin is allowed to do it. Using Vista x64. I solved this by changing the security properties of the folder, however I suppose many users would appreciate if the installer uses the commonly known UAC dialog :)
Re: Administrator rights for installer
WinSCP installer pops up UAC prompt when run by admin user only. This is to allow non-admin users to run the installer (installing WinSCP to user folder).
Unfortunately, installer tool used by WinSCP (InnoSetup) does not support delayed UAC prompts that would be triggered only after user chooses installation folder writtable by admin only. I'll investigate if there some other solution.
You can always explicitly require running installer by admin. Right-click the installer file and select Run as administrator.
