Second commandline fails
Floatingshed
I am using the following commandline in a batch file:
"c:\Program Files\winscp\winscp.com" /command "option batch abort" "option confirm off" "open ftp://password:username@server.com" "rm ""/Temp/File_to_delete.plp""" "exit"
It works fine. However I want to delete the same file from another server at the same time. So I duplicate the line and simply change the server credentials. The second line fails with a "file not found" error. I can reverse the order of the two command lines, it is always the second one that fails.
Please help.
Thanks.
Re: Second commandline fails
To generate log file, use /log=path_to_log_file command-line argument. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
