Topic ""Synchronized browsing" greyed out"
whitecat
I'm new to WinSCP but now that I have finished building my new PC I wanted to take the opportunity to get rid of my jurassic WS_FTP Very Happy
I configured some of my regular FTP connections and everything is working fine with one exception: I want to use the handy "Synchronized Browsing" feature, but the checkbox is greyed out, so I'm not able to activate this option (see attached screenshot). I'm using the "Commander" interface. I typed in the "Remote directory" and "Local directory" paths which work as they should, but the synchronization of the local and remote dirs fails.
Are there some circumstances where "Synchronized Browsing" does not work?
OS is Windows 8.1 64 Bit. WinSCP 5.5.1 (Build 3970).
Thank you.
whitecat
Description: Screenshot
No idea? I reinstalled WinSCP but got the same effect...
Make sure that Remember panels state when switching sessions is enabled
http://winscp.net/eng/docs/ui_pref_panels#common
and Do not change state when switching sessions is disabled
http://winscp.net/eng/docs/ui_pref_panels_local
Both is default.
See also
http://winscp.net/eng/docs/ui_login_directories#directories
whitecat
Sorry for the late answer - I haven't got a notification mail and stumbled upon my entry by accident...
This was it! Thank you for your useful hint.
whitecat
