Topic "window size"
newbie
any advice how to make the window size stick?
Hv to re-size application every time I open winscp 3.6.1 built 221
Window size should be remembered always. Did the problem appear with 3.6.1 or did you have it even with older versions?
Dear Martin,
the window size not sticking, did also happen with older versions.
Thanx for your help
Hmm, hard to tell. What is your screen resolution? Do you have the WinSCP window maximized when exiting? If not, is it whole "on the screen", or is some edge of the window outside the screen?
If you know how to work with Windows registry, then please after exiting the program, export key
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander] or [HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Explorer] (it depends on what interface you use) and post the exported settings.
1024x768
the width always stays the same when minimized, the length of the window has to be adjusted. It is always below the visible window when opening scp.
thanx for all the help.
hope this is what you are looking for, maybe not the format.
Key Name: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander
Class Name: <NO CLASS>
Last Write Time: 28/05/2004 - 10:24
Value 0
Type: REG_SZ
Data: 5,0,0,219,6;1,1,0,249,5;4,0,0,227,4;3,1,0,137,3;6,1,0,145,2;2,1,1,104,1;0,1,1,644,0
Value 1
Type: REG_DWORD
Data: 0x0
Value 2
Type: REG_BINARY
Data:
00000000 00 00 00 00 00 00 e0 3f - ......?
Value 3
Type: REG_DWORD
Data: 0x1
Value 4
Type: REG_DWORD
Data: 0x0
Value 5
Type: REG_DWORD
Data: 0x1
Value 6
Type: REG_SZ
Data: -1;-1;600;400;0
Value 7
Type: REG_DWORD
Data: 0x0
Value 8
Type: REG_DWORD
Data: 0x0
Value 9
Type: REG_DWORD
Data: 0x1
Value 10
Type: REG_DWORD
Data: 0x0
Value 11
Type: REG_DWORD
Data: 0x0
Key Name: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander\LocalPanel
Value 0
Type: REG_SZ
Data: 2,1,0,137,2;1,1,0,86,1;0,1,1,91,0
Value 1
Type: REG_SZ
Data: 0;1;0|150,1;70,1;101,1;79,1;62,1;55,0|0;1;2;3;4;5
Value 2
Type: REG_DWORD
Data: 0x1
Key Name: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander\RemotePanel
Value 0
Type: REG_SZ
Value 1
Type: REG_SZ
Value 2
Type: REG_DWORD
Data: 0x1
Quote:
1024x768
Are you sure you are using the Norton-Commander interface of WinSCP? You configuration contains only the default options (I mean not only the window size), which should happen only if you never used the interface. Or there are some problems saving your configuration. Are other options being saved (like options on preferences dialog)?
Dear Martin, the options in preferences are saved.
Norton interface is selected.
The preferences on login are saved as well, although in both casses the menu
is always expanded when opening. ( - instead of +)
thanx
Jo
I have other problems with scp, but as you can see even the window size takes several posts
As I have no idea how to help you with the window size problem now, let try to fix the other.
