Topic "Error transferring files from remote side"
robertko
I tried searching the forum but couldn't find an answer to the problem I have. I just set up WinSCP 5.5.1 on Windows 7 to connect to a NAS using FTP. Whenever I transfer files from the NAS to the local computer I get the error message "Transferring files from remote side failed" (I dunno if this is the exact message, cause it's in dutch) after transferring the file! Then it gives me the option to abort, skip, overwrite, continue, whatever. I can then Skip it, because the file did transfer and seems to be okay. This happens for every file. What could be causing this error?
UPDATE:
It seems this error only appears when doing multiple transfers. When I transfer one file at a time, no error appears.
Thanks for the support!
Robert
