Topic "SFTP Connection - Session.Open; ERROR: Temporary File in use"
Moneyblind
Hello! I am running into an issue; I have taken the overall example C# code and modified it to match my credentials and host account. However, the TEMPORARY file that is created by Session.Open is returning this error.
A first chance exception of type 'System.IO.IOException' occurred in mscorlib.dll
Additional information: The process cannot access the file 'C:\Users\Admin\AppData\Local\Temp\wscp24C0.0223CC89.tmp' because it is being used by another process.
Here is the code:
Quote:
private bool uploadFile(string path, string hostName, string username, string password)
try
// Setup session options
Protocol = Protocol.Sftp,
HostName = hostName,
UserName = username,
Password = password,
SshHostKeyFingerprint = "ssh-rsa 1024 **:**:**:**:20:8f:95:69:12:f5:52:**:**:**:**:**"
// Connect
session.Open(sessionOptions);
// Upload files
TransferOptions transferOptions = new TransferOptions();
transferOptions.TransferMode = TransferMode.Binary;
TransferOperationResult transferResult;
transferResult = session.PutFiles(path, "/", false, transferOptions);
// Throw on any error
transferResult.Check();
// Print results
foreach (TransferEventArgs transfer in transferResult.Transfers)
Console.WriteLine("Upload of {0} succeeded", transfer.FileName);
return true;
catch (Exception e)
Console.WriteLine("Error: {0}", e);
return false;
Moneyblind
This is where the error is thrown;
// Connect
Please post a callstack of the extension.
MichaelMotes
I have this same problem, here is the callstack:
mscorlib.dll!System.IO.__Error.WinIOError(int errorCode, string maybeFullPath) + 0x321 bytes
mscorlib.dll!System.IO.FileStream.Init(string path, System.IO.FileMode mode, System.IO.FileAccess access, int rights, bool useRights, System.IO.FileShare share, int bufferSize, System.IO.FileOptions options, Microsoft.Win32.Win32Native.SECURITY_ATTRIBUTES secAttrs, string msgPath, bool bFromProxy, bool useLongPath) + 0x477 bytes
mscorlib.dll!System.IO.FileStream.FileStream(string path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share) + 0x54 bytes
mscorlib.dll!System.IO.File.Open(string path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share) + 0x25 bytes
WinSCPnet.dll!WinSCP.SessionLogReader.OpenLog() + 0xd1 bytes
WinSCPnet.dll!WinSCP.SessionLogReader.DoRead() + 0x64 bytes
WinSCPnet.dll!WinSCP.SessionLogReader.Read(WinSCP.LogReadFlags flags) + 0x86 bytes
WinSCPnet.dll!WinSCP.CustomLogReader.TryWaitForNonEmptyElement(string localName, WinSCP.LogReadFlags flags) + 0x5f bytes
WinSCPnet.dll!WinSCP.CustomLogReader.WaitForNonEmptyElement(string localName, WinSCP.LogReadFlags flags) + 0x29 bytes
WinSCPnet.dll!WinSCP.CustomLogReader.WaitForNonEmptyElementAndCreateLogReader(string localName, WinSCP.LogReadFlags flags) + 0x29 bytes
WinSCPnet.dll!WinSCP.Session.Open(WinSCP.SessionOptions sessionOptions) + 0x775 bytes
MichaelMotes
This error only occurs on my old XP dev machine. My new Win7 dev machine doesn't experience any issue with the same code. I suppose XP is official dead and dying. Crying or Very sad Mad Rolling Eyes Wink Razz Laughing I get carried away with emoticons. Very Happy
I have sent you an email.
adnanaman
I am having the same exception but on windows 7... i have described my issue here http://winscp.net/forum/viewtopic.php?t=14755
Gurmeet
This is happening when I am trying to compile VS 2013 solution
System.TypeInitializationException was unhandled
Message: An unhandled exception of type 'System.TypeInitializationException' occurred in mscorlib.dll
Additional information: The type initializer for 'XXXXX' threw an exception.
using (Session sess = new Session())
//sess.SessionLogPath = @"C:\GUR";
sess.Open(sessionOptions);
//Get Ftp File
transferOptions.TransferMode = TransferMode.Binary; //The Transfer Mode -
transferOptions.FilePermissions = new FilePermissions(0666); //Permissions applied to remote files. 0666 is read/write
transferOptions.PreserveTimestamp = false; //Set last write time of
transferOptions.ResumeSupport.State = TransferResumeSupportState.Off;
transferResult = sess.PutFiles(fileName, ConfigurationManager.AppSettings["SFTPToPath"], false, transferOptions);
Victor78
Fack you guys who made this shity winscp, I'm lost my 2 weeks job because i' used this crap program.
Isn't save anything just after few try because this is the full of Shlt software
What is the XXXX? Anyway, please start a new thread. I do not see how's your problem related to this topic.
