Topic "Set a default directory to use when the previous one..."
larsen
I often open sessions that last time had a local directory opened that now doesn´t exist anymore. Each time I get a warning and WinSCP uses some user folder.
I would like to get rid of that warning message and specify a default directory that WinSCP uses if the old one cannot be opened. Is this already possible or could you put this on the wish-list?
Lars
PS: Could you increase the maximum length of a subject in this forum? A little bit too small to create a meaningful subject.
You can make WinSCP not remember the last used directory and always start in configured folder.
Just uncheck Remember last used directory:
http://winscp.net/eng/docs/ui_login_directories
OK, added to TODO.
larsen
That could be a workaround.
As I have many connections, I tried to change it for one and then checked the INI file, but I couldn´t find a changed setting for the host. Where in the INI is it saved?
In recent versions of WinSCP, it is a default. So an absence of UpdateDirectories key makes it turn on.
larsen
Thx, that worked fine.
