Topic "Unable to create new directory"
AIXman
I am using WinSCP 3.6.1 to connect to several AIX servers, using an RSA key and SSH2 protocol. On some servers, I am able to create subdirectories in my home directory. In others, I am not, and I receive a "Permission denied" error. I can login via PuTTY and have full access.
It appears to be an SFTP/SCP issue. If I successfully login with WinSCP via SFTP, I cannot create a subdirectory, called "New". If the login fails and I fallback to SCP, I can create the subdirectory.
The failure seems to be that the full path to the new directory is incorrect, i.e. it omits the final "/" before the new directory name.
I am including two log files (with server names and IP addresses masked). First, the successful version:
. WinSCP Version 3.6.1 (Build 221) (OS 5.0.2195 Service Pack 3)
. Login time: Friday, June 04, 2004 12:54:42 PM
. Session name: sbassle@xxxxxxxx
. Host name: xxxxxxxx (Port: 22)
. User name: sbassle (Password: No, Key file: No)
. Transfer Protocol: SFTP (SCP)
. SSH protocol version: 2; Compression: Yes
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs:
. Proxy: none
. Shell: default, EOL: 0
. Cache directory changes: Yes, Permanent: Yes
. Looking up host "xxxxxxxx"
. Connecting to nn.nn.nn.nn port 22
. Server version: SSH-2.0-OpenSSH_3.7.1p1-pwexp24
. We claim version: SSH-2.0-WinSCP-release-3.6.1
. Host key fingerprint is:
. ssh-rsa 1024 d2:ec:38:2d:42:02:ba:17:4c:4d:f2:24:d6:a5:7b:e2
! Using username "sbassle".
. Pageant is running. Requesting keys.
. Pageant has 1 SSH2 keys
. Trying Pageant key #0
! Authenticating with public key "rsa-key-20011010" from agent
. Sending Pageant's response
. Access granted
. Opened channel for session
. Primary command failed; attempting fallback
. Started a shell/command
. Using SCP protocol.
> echo "WinSCP: this is end-of-file:0"
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
. Trying "$?".
> echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$?" selected.
. Clearing all aliases.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
< WinSCP: this is end-of-file:1
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
> unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
> unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
> unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
> unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
> unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
> unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
> unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
> unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
> unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
> unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
> unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
> unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
> unalias "alias" ; echo "WinSCP: this is end-of-file:$?"
> unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
> unalias "%s" ; echo "WinSCP: this is end-of-file:$?"
. Clearing national user variables.
> unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
> unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
> unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
. Looking up groups and users.
> groups ; echo "WinSCP: this is end-of-file:$?"
< system staff lgsvr
. Following groups found:
. system
. staff
. lgsvr
. No users found.
> pwd ; echo "WinSCP: this is end-of-file:$?"
< /home/sbassle
. Listing current directory.
> ls -la ; echo "WinSCP: this is end-of-file:$?"
< total 130868
< drwxr-x--- 4 sbassle lgsvr 1024 Jun 4 12:53 .
< drwxr-xr-x 56 root system 1536 May 28 10:36 ..
< -rw------- 1 sbassle system 432 Jun 4 12:53 .Xauthority
< -rwxr----- 1 sbassle system 735 Sep 2 2003 .profile
< -rw------- 1 sbassle system 4804 Jun 4 12:53 .sh_history
< drwxr-x--- 2 sbassle system 512 Mar 3 08:08 .ssh
< -rw-r----- 1 sbassle system 46421 Mar 10 15:18 1163.txt
< -rw-r----- 1 sbassle system 2286 Jan 16 13:40 TDP_upgrades.txt
< drwxr-x--- 2 sbassle system 512 Dec 1 2003 TSM5.2_64bit
< -rwxrwxr-x 1 root system 821 Oct 6 2003 assign.pl
< -rwxr-xr-x 1 root system 590 Sep 9 2003 assign.pl.old
< -rw-r----- 1 sbassle system 136724 Mar 22 14:51 data
< -rw-r----- 1 sbassle system 188 Jan 13 10:53 dsmerror.log
< -rw-r----- 1 sbassle system 10434560 Dec 3 2003 hostAgent-AIX.tar
< -r--r----- 1 sbassle system 6967 May 28 13:43 inetd.conf
< -rw-r----- 1 sbassle system 45342720 Feb 3 11:44 jre14.tar
< -rw-r----- 1 sbassle system 234 May 6 13:54 no_sendmail
< -rwxr-xr-x 1 root system 8201 Sep 8 2003 notify.sh
< -rw-r----- 1 sbassle system 701401 Sep 19 2003 openssh-3.7.1p1-pwexp24.patch.txt
< -rw-r----- 1 sbassle system 3614720 Sep 17 2003 openssh-3.7.1p1.tar
< -rw-r----- 1 sbassle system 622649 Sep 17 2003 openssh-3.7p1-pwexp24.patch.txt
< -rw-r----- 1 sbassle system 3768320 Apr 8 12:00 openssh-3.8p1.tar
< -rwxr-x--- 1 sbassle system 2004564 Nov 19 2003 openssl-0.9.6.7.exe
< -rw-r----- 1 sbassle system 61716 May 23 2001 setup.ini
< -rw-r--r-- 1 sbassle system 38503 Jun 2 10:47 smit.log
< -rw-r--r-- 1 sbassle system 5281 Nov 18 2003 smit.script
< -rw-r----- 1 sbassle system 518 Jun 2 12:22 tcpd.txt
< -rwxr-x--- 1 sbassle system 339 May 14 12:45 test
< -rw-r----- 1 sbassle system 81700 Aug 1 2003 tsmtrace.dos
< -rw-r----- 1 sbassle system 82678 Aug 1 2003 tsmtrace.txt
. Startup conversation with host finished.
. Creating directory "New".
> mkdir "New" ; echo "WinSCP: this is end-of-file:$?"
< total 130869
< drwxr-x--- 5 sbassle lgsvr 1024 Jun 4 12:55 .
< drwxr-x--- 2 sbassle system 512 Jun 4 12:55 New
. Closing connection.
Next, the unsuccessful version:
. Login time: Friday, June 04, 2004 12:50:40 PM
. Session name: sbassle@yyyyyyyy
. Host name: yyyyyyyy (Port: 22)
. SSH Bugs:
. Proxy: none
. Looking up host "yyyyyyyy"
. ssh-rsa 1024 e6:48:ea:77:90:21:ef:ab:cf:a8:3e:1a:01:85:37:5b
. Access granted
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 5, Number: -1
. SFTP version 3 negotiated.
> Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
< Type: SSH_FXP_STATUS, Size: 38, Number: 200
< Status/error code: 8
. Server does not recognise WinSCP.
. Getting real path for '.'
> Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< Type: SSH_FXP_NAME, Size: 47, Number: 528
. Real path is '/home/sbassle'
. Listing directory "/home/sbassle".
> Type: SSH_FXP_OPENDIR, Size: 22, Number: 779
< Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< Type: SSH_FXP_NAME, Size: 1681, Number: 1036
> Type: SSH_FXP_READDIR, Size: 13, Number: 1292
< Type: SSH_FXP_STATUS, Size: 28, Number: 1292
< Status/error code: 1
> Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
< Type: SSH_FXP_STATUS, Size: 24, Number: 1540
< Status/error code: 0
. Canonifying: "New"
. Getting real path for '/home/sbassle/New'
> Type: SSH_FXP_REALPATH, Size: 26, Number: 2064
< Type: SSH_FXP_NAME, Size: 53, Number: 2064
. Real path is '/home/sbassleNew'
. Canonified: "/home/sbassleNew"
> Type: SSH_FXP_MKDIR, Size: 29, Number: 1806
< Type: SSH_FXP_STATUS, Size: 34, Number: 1806
< Status/error code: 3, Message: 1806, Server: Permission denied, Language: *
. Asking user:
. Can't create folder 'New'. ("Permission denied.
. Error code: 3
. Error message from server: Permission denied (*)
. Request code: 14")
Thanks for your help and a great product!
Steve Bassler
AIXman
Additional information:
I found out why the SFTP login was failing on the one server. In the SSHD configuration file, I had the wrong path for the SFTP subsystem. I corrected this, so I can now login there with SFTP. However, that means that on this server I can also no longer create a subdirectory unless I force it to use SCP. :(
Steve
Can I have a test account on the server? If not, can you test it with other SFTP client, like PSFTP?
AIXman
It's on an internal network, so no, I can't give you an account. Here are a couple of tests, the first with native command-line SSH from another AIX server, the second with PSFTP. Interestingly, creating a subdirectory works with SSH but not with PuTTY.
Again, the server name and IP address are masked.
SSH:
$ sftp -vvv xxxxxxxx
Connecting to xxxxxxxx...
OpenSSH_3.7.1p1-pwexp24, SSH protocols 1.5/2.0, OpenSSL 0.9.6c 21 dec 2001
debug1: Reading configuration data /usr/local/etc/ssh_config
debug2: ssh_connect: needpriv 0
debug1: Connecting to xxxxxxxx [nn.nn.nn.nn] port 22.
debug1: Connection established.
debug3: Not a RSA1 key file /home/sbassle/.ssh/id_rsa.
debug2: key_type_from_name: unknown key type '-----BEGIN'
debug3: key_read: missing keytype
debug2: key_type_from_name: unknown key type 'Proc-Type:'
debug2: key_type_from_name: unknown key type 'DEK-Info:'
debug3: key_read: missing whitespace
debug2: key_type_from_name: unknown key type '-----END'
debug2: key_type_from_name: unknown key type '----'
debug1: identity file /home/sbassle/.ssh/id_rsa type 1
debug1: identity file /home/sbassle/.ssh/id_dsa type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_3.7.1p1-pwexp24
debug1: match: OpenSSH_3.7.1p1-pwexp24 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_3.7.1p1-pwexp24
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,arcfour,aes192-cbc,aes256-cbc,rijndael-cbc@lysator.liu.se,aes128-ctr,aes192-ctr,aes256-ctr
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: mac_init: found hmac-md5
debug1: kex: server->client aes128-cbc hmac-md5 none
debug1: kex: client->server aes128-cbc hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug2: dh_gen_key: priv key bits set: 134/256
debug2: bits set: 1596/3191
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug3: check_host_in_hostfile: filename /home/sbassle/.ssh/known_hosts
debug3: check_host_in_hostfile: match line 5
debug1: Host 'xxxxxxxx' is known and matches the RSA host key.
debug1: Found key in /home/sbassle/.ssh/known_hosts:5
debug2: bits set: 1617/3191
debug1: ssh_rsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /home/sbassle/.ssh/id_rsa (200deeb8)
debug2: key: /home/sbassle/.ssh/id_dsa (0)
debug1: Authentications that can continue: publickey,password,keyboard-interactive
debug3: start over, passed a different list publickey,password,keyboard-interactive
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering public key: /home/sbassle/.ssh/id_rsa
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug1: Server accepts key: pkalg ssh-rsa blen 149
debug2: input_userauth_pk_ok: fp 71:0d:30:3b:af:92:ab:a6:35:a5:5c:24:66:19:9a:e6
debug3: sign_and_send_pubkey
debug1: Authentication succeeded (publickey).
debug2: fd 5 setting O_NONBLOCK
debug2: fd 6 is O_NONBLOCK
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug1: Entering interactive session.
debug2: callback start
debug2: ssh_session2_setup: id 0
debug1: Sending subsystem: sftp
debug2: channel 0: request subsystem
debug2: callback done
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug2: channel 0: rcvd adjust 131072
debug2: Remote version: 3
debug3: Sent message fd 3 T:16 I:1
debug3: SSH_FXP_REALPATH . -> /home/sbassle
sftp> ls -l
ebug3: Sent message fd 3 T:7 I:2
debug3: Received stat reply T:105 I:2
debug3: Sent message fd 3 T:7 I:3
debug3: Received stat reply T:105 I:3
debug3: Sending SSH2_FXP_READDIR I:5
debug3: Received reply T:104 I:5
debug3: Received 31 SSH2_FXP_NAME responses
debug3: Sending SSH2_FXP_READDIR I:6
debug3: Received reply T:101 I:6
debug3: Received SSH2_FXP_STATUS 1
debug3: Sent message SSH2_FXP_CLOSE I:7
debug3: SSH2_FXP_STATUS 0
drwxr-x--- 0 304 300 1024 Jun 7 07:54 .
drwxr-xr-x 0 0 0 1536 May 28 10:36 ..
-rw------- 0 304 0 432 Jun 7 07:54 .Xauthority
-rwxr----- 0 304 0 735 Sep 2 2003 .profile
-rw------- 0 304 0 5504 Jun 7 08:31 .sh_history
drwxr-x--- 0 304 0 512 Mar 3 08:08 .ssh
-rw-r----- 0 304 0 46421 Mar 10 15:18 1163.txt
drwxr-x--- 0 304 0 512 Jun 4 12:55 New
-rw-r----- 0 304 0 2286 Jan 16 13:40 TDP_upgrades.txt
drwxr-x--- 0 304 0 512 Dec 1 2003 TSM5.2_64bit
-rwxrwxr-x 0 0 0 821 Oct 6 2003 assign.pl
-rwxr-xr-x 0 0 0 590 Sep 9 2003 assign.pl.old
-rw-r----- 0 304 0 136724 Mar 22 14:51 data
-rw-r----- 0 304 0 188 Jan 13 10:53 dsmerror.log
-rw-r----- 0 304 0 10434560 Dec 3 2003 hostAgent-AIX.tar
-r--r----- 0 304 0 6967 May 28 13:43 inetd.conf
-rw-r----- 0 304 0 45342720 Feb 3 11:44 jre14.tar
-rw-r----- 0 304 0 234 May 6 13:54 no_sendmail
-rwxr-xr-x 0 0 0 8201 Sep 8 2003 notify.sh
-rw-r----- 0 304 0 701401 Sep 19 2003 openssh-3.7.1p1-pwexp24.patch.txt
-rw-r----- 0 304 0 3614720 Sep 17 2003 openssh-3.7.1p1.tar
-rw-r----- 0 304 0 622649 Sep 17 2003 openssh-3.7p1-pwexp24.patch.txt
-rw-r----- 0 304 0 3768320 Apr 8 12:00 openssh-3.8p1.tar
-rwxr-x--- 0 304 0 2004564 Nov 19 2003 openssl-0.9.6.7.exe
-rw-r----- 0 304 0 61716 May 23 2001 setup.ini
-rw-r--r-- 0 304 0 38503 Jun 2 10:47 smit.log
-rw-r--r-- 0 304 0 5281 Nov 18 2003 smit.script
-rw-r----- 0 304 0 518 Jun 2 12:22 tcpd.txt
-rwxr-x--- 0 304 0 339 May 14 12:45 test
-rw-r----- 0 304 0 81700 Aug 1 2003 tsmtrace.dos
-rw-r----- 0 304 0 82678 Aug 1 2003 tsmtrace.txt
sftp> mkdir new2
debug3: Sent message fd 3 T:14 I:8
sftp> ls -l
debug3: Sent message fd 3 T:7 I:9
debug3: Received stat reply T:105 I:9
debug3: Sent message fd 3 T:7 I:10
debug3: Received stat reply T:105 I:10
debug3: Sending SSH2_FXP_READDIR I:12
debug3: Received reply T:104 I:12
debug3: Received 32 SSH2_FXP_NAME responses
debug3: Sending SSH2_FXP_READDIR I:13
debug3: Received reply T:101 I:13
debug3: Sent message SSH2_FXP_CLOSE I:14
drwxr-x--- 0 304 300 1024 Jun 7 08:32 .
drwxr-x--- 0 304 0 512 Jun 7 08:32 new2
sftp> quit
debug2: channel 0: read<=0 rfd 5 len 0
debug2: channel 0: read failed
debug2: channel 0: close_read
debug2: channel 0: input open -> drain
debug2: channel 0: ibuf empty
debug2: channel 0: send eof
debug2: channel 0: input drain -> closed
debug2: channel 0: rcvd eof
debug2: channel 0: output open -> drain
debug2: channel 0: obuf empty
debug2: channel 0: close_write
debug2: channel 0: output drain -> closed
debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
debug2: channel 0: rcvd close
debug3: channel 0: will not send data after close
debug2: channel 0: almost dead
debug2: channel 0: gc: notify user
debug2: channel 0: gc: user detached
debug2: channel 0: send close
debug2: channel 0: is dead
debug2: channel 0: garbage collecting
debug1: channel 0: free: client-session, nchannels 1
debug3: channel 0: status: The following connections are open:
#0 client-session (t4 r0 i3/0 o3/0 fd -1/-1)
debug3: channel 0: close_fds r -1 w -1 e 7
debug1: fd 0 clearing O_NONBLOCK
debug2: fd 1 is not O_NONBLOCK
debug1: Transferred: stdin 0, stdout 0, stderr 0 bytes in 30.6 seconds
debug1: Bytes per second: stdin 0.0, stdout 0.0, stderr 0.0
debug1: Exit status 0
PSFTP:
C:\>psftp -v xxxxxxxx
We claim version: SSH-2.0-PuTTY-Release-0.54
Access granted
Connected to xxxxxxxx
Remote working directory is /home/sbassle
psftp> ls
Listing directory /home/sbassle
drwxr-x--- 6 sbassle lgsvr 1024 Jun 7 08:32 .
-rw------- 1 sbassle system 432 Jun 7 07:54 .Xauthority
-rw------- 1 sbassle system 5504 Jun 7 08:31 .sh_history
drwxr-x--- 2 sbassle system 512 Jun 7 08:32 new2
psftp> mkdir new3
mkdir /home/sbasslenew3: permission denied
psftp> mkdir /home/sbassle/new3
psftp> quit
Sent EOF message
Server sent command exit status 0
All channels closed. Disconnecting
C:\>
Thanks again for your help,
Steve
OK, I'll prepare debug version of WinSCP and contact you tomorrow at your email address.
