Topic "Uploading many files at once - ftp"
ehd
great program, thank you very much!
But there is one thing I cannot really figure out.
If I drag one directory to the remote ftp-server, there will be only one background-transfer started at the same time, despite I configured 9.
If I drag 5 selected files to the remote ftp-server there will be only one background-transfer started at the same time.
If I drag 5 selected files ONE AFTER ANOTHER to the remote ftp-server there will be FIVE background-transfers started at the same time. Great!
But how do I manage to upload an entire directory with many subdirectories with automatically the max. number of background transfers are being started automatically?
If have tried this over and over again, but couldn't find out how.
Thanks alot!
ehd
Anyone please?
ehd
Is it possible or not? Question
See Transfer each file individually on background by default:
http://winscp.net/eng/docs/ui_pref_background
This request is being tracked already:
http://winscp.net/tracker/show_bug.cgi?id=875
ehd
Thanks alot! That would be awesome to see the new feature soon!
ehd
BTW,
how do you all realize uploading many files at once recursed into subdirectories?
It takes ***ages*** for directories with hundreds of files.
Thanks for you hints
ehd
Does anybody upload more than 10 files?
ehd
Thanks for your answer, I made annotated screenshots, that may explain what I mean:
Description: (none)
Description: (none)
OK, so you do not think that WinSCP is slow as such when transferring lots of small files in a row? (comparing to other file transfer clients?)
ehd
it does not recurse file from subdirectories and downloads them not at once but one after another:
WInSCP:
directory -> file -> file -> file -> file (one thread at a time)
FOr example filezilla:
directory
-> file
-> file
-> file
-> file (4 threads at a time)
hello_world
Sure, I guess this will be quite useful.
Please consider to fix this.
Thanks!
another_user
Still not fixed Mad
