Topic "Can't use private key to auth"
MikeDawg
Using latest WinSCP 5.5.1. I'm unable to use private key for authentication, inside WinSCP.
I got to configure the sftp site I'm attempting to connect to, I go to Advanced Site Settings, go to SSH -> Authentication -> Private key file:
Now, beforehand, I was given a private key file, from openssh. I opened it in Pagent, and converted (exported private key) as a PPK file. When I try and select this PPK, I get the error message:
"File '"C:\<path to ppk>\private_key.ppk"' does not exist or it does not contain private key in known format."
This same PPK file, however, will load into pagent, and I can auth using WinSCP and pagent; but I would just like to cut out the pagent middle-man, and just run the auth from WinSCP.
Simon T
This happens if the path or file name contains spaces. WinSCP adds quotes at the beginning and end of the "Private key file" field which causes the error message. Deleting the quotes fixed the problem for me.
MikeDawg
That was the problem. Thank you sir!
Thanks for your report and resolution!
http://winscp.net/tracker/show_bug.cgi?id=1130
thedudeza
Thank y ou so much!!!
