Topic "WinSCP TSQL Script Issue"
0xygen
Hey everyone,
my .bat file that opends a .txt file works fine when i doubleklick it or start it with a cmd window. But when i try to start it with XP_CMDSHELL in TSQL nothing happened. I have created an trigger that should sync 2 folders after an insert / update was made. Well the insert / update is fired and i got my callbacks (so it works fine) but the sync is not working. I called it like this:
SET @cmd = 'sync.bat'; exec xp_cmdshell @cmd;
Well as i said i read the documentation and so on. Everything works fine except starting the .bat file from tsql / xp_cmdshell.
Anyone can help me?
If the problem is about starting a .bat file, it does not seem to be relevant to this forum. Please consider asking on http://superuser.com/ or similar.
